Latest: ArtistKS
Overall: 17145
Online Now [47]:
Visitors: 46
Today: 17196
Total: 115958081
Forums › The Car › 206 Problems › door trim
door trim
jack32100
PostPosted: Mon Nov 25, 2013 3:37 pm Up
please could some one tell me how the door trims are attatched the doors, ie stuck clips bolted , many thanks
Seatock789
PostPosted: Mon Nov 25, 2013 3:41 pm Up
Which one's? The outer strips or the inner door cards?
jack32100
PostPosted: Mon Nov 25, 2013 3:46 pm Up
the large curved outer ones
Seatock789
PostPosted: Mon Nov 25, 2013 3:52 pm Up
Best way to do this is to remove the inner door card & insulation and push the clips out from the inside. Once you get 1 out the rest tend to follow, from what I can remember there are 2 difficult one's in the middle of the door where I just pulled from the outside.....Be careful because the end nearest the door lock is not a push clip, it kind of hooks over so once all the push clips are undone you need to pull it along the door towards the front wheel......The tabs break easily, I know, I've done it.
You'll probably need some spare push clips as they tend to break as well.
jack32100
PostPosted: Mon Nov 25, 2013 4:07 pm Up
many thanks for your help need to replace a black one with a blue one much apreciated jack32100
PostPosted: Tue Nov 26, 2013 3:39 am Up
Pretty sure you don't need to take anything off the inside. You slide and pull.
Inevitably you may get a couple of clips snapping, but they cost pennies from the dealer
Edit. Just done a quick search and this confirms it
www.206info.co.uk/Foru...c/t=33213/
Seatock789
PostPosted: Tue Nov 26, 2013 7:00 am Up
Just checked with my old one's, you need to pull it towards the door lock once you have all the clips undone.
You could get away without taking anything off from the inside but it does make it easier if you do.
