Latest: heikkisj
Overall: 17126
Online Now [43]:
Visitors: 42
Today: 15975
Total: 100213583
Forums › The Car › 206 Talk › fastest 206 on world?
rckid
PostPosted: Wed Jan 09, 2013 3:41 am Up
this is video of my gti180 running 100-200kmhs @ 5.761 sec
www.youtube.com/watch?v=k3w2D9F2QNE
206RC/gti180 turbo
PostPosted: Wed Jan 09, 2013 4:07 am Up
thats insane!!
PostPosted: Wed Jan 09, 2013 4:40 am Up
Why's the EML on?
Mr_Akina
PostPosted: Wed Jan 09, 2013 5:14 am Up
macca1411 wrote:
Why's the EML on?
It's a 206?
rckid
PostPosted: Wed Jan 09, 2013 5:34 am Up
Because we are running a standalone ecu parallel to original one
206RC/gti180 turbo
PostPosted: Wed Jan 09, 2013 6:01 am Up
Just remove the bulb!
JamieM
PostPosted: Wed Jan 09, 2013 7:11 am Up
Yeah I heard if you run a standalone parallel to the original one they can keep the multiplexed shizzle. I'm sure it's not new news but I always remember Jamie's anti-climax thread because Sandy Brown couldn't perform the upgrade without issues.
That car sounds mental.
Aegean Blue 206 GTi180
PostPosted: Wed Jan 09, 2013 11:55 am Up
I dont think Sandy wanted to risk the car not working if he removed half the engine loom. It can be done though. For example what knock on effect does removing the cars control of the throttle have on the ESP system?
Mattie-RS
PostPosted: Wed Jan 09, 2013 12:10 pm Up
I would imagine the ESP would be in constant fault, i think this was one of the reasons Jamie didnt do it.
Not sure but maybe you could write the control of the ETB out but then imagine it still cutting detonation with full throttle still applied.
I think the only available function would be the brakes, by then you might aswell just have it completely disabled
00budham00
PostPosted: Wed Jan 09, 2013 1:00 pm Up
Ohhhhh I messed myself
HDI90
PostPosted: Wed Jan 09, 2013 1:35 pm Up
His flyby video is mental!
GTI 180
PostPosted: Wed Jan 09, 2013 2:36 pm Up
wow
Johnbyron
PostPosted: Wed Jan 09, 2013 2:51 pm Up
That exhaust note on the fly by is perfect !!!
jonsully
PostPosted: Wed Jan 09, 2013 2:56 pm Up
mega car! Smile
2000 gti 138,tein superstreet coilovers front,tein adjustable shocks rear,22mm rear arb,carbon fibre strut brace, 6 point omp cage,fibre glass bonnet,polycarb windows,406 v6 brembo 4 pots,carbon Lorraine rc6 pads,brembo 307hdi front discs,406 v6 master cylinder,braided hoses all round,306 gti-6 brake reservoir,abs removed,4.9 cwp with 3j driveline plated lsd,compbrake quickshift,k&n filter with cold air feed pipe,4 branch mani,decat,sportex straight thru race system,mocal oil cooler,group n engine mounts,omp bucket seats,omp steering wheel,battery relocated to boot,4 point harnesses,15'team dynamics pro race 1.2 on Michelin slicks
rckid
PostPosted: Wed Jan 09, 2013 3:11 pm Up
www.youtube.com/watch?...r_embedded
check out the placement of exhaust pipe:)
206RC/gti180 turbo
