Latest: lio94
Overall: 17181
Online Now [156]:
Visitors: 155
Today: 46143
Total: 140842775
Forums › The Car › 206 Problems › Spilt coffee on dash
chopsim1
PostPosted: Sat Nov 23, 2013 6:06 am Up
This morning i spilt a large coffee over the dash in my 1.4 01 pug. All over the key which was in the ignition, all down the fascia over the headlight adjust switches etc.
My car will turn over but wont fire up. Checked the fuses and they seem ok.
Opened the key and that is dry. Central locking works fine via the fob. Everything else works, it just wont fire up.
Please can anyone help?
PostPosted: Sat Nov 23, 2013 6:52 am Up
Damn!
That's a weird one?!
Ignition aerial (around and behind cowling at ignition cylinder barel) could be an issue if you got it wet while cleaning afterwards. That aerial (coil) picks up the signal from the immo chip inside the key.
Can't think of anything else so try a hairdrier around the barrel area.
PostPosted: Sat Nov 23, 2013 6:59 am Up
Also try liberal quantity of contact spray in the ignition switch hole if coffee was with milk and sugar in it.
PostPosted: Sat Nov 23, 2013 7:15 am Up
Possibly dripped down the cowling and into the fuse box.
Yes, buy one of these to put your coffee in.
mattymj
PostPosted: Sat Nov 23, 2013 7:35 am Up
Was there sugar in the coffee? My car wont start unless there are 2
chopsim1
PostPosted: Sat Nov 23, 2013 7:36 am Up
Yeah Yeah...thank you Macca. The fuses that i could see looked ok.
Im going to the car tomorrow as i had it recovered to my work yard.
V9977....it was a capuchino with sweetener...I have a can of contact spray. I'll try that. Hairdryer good idea but i'm male, single with a shaved head.
I have a spare key with no electrics in it, just a basic key. I will try that aswell. But how will that work if its just a standard key?
Thanks for reading
PostPosted: Sat Nov 23, 2013 8:15 am Up
Laughing
If your spare key is the black factory one (no buttons) that has an immo chip inside and it should work fine
Otherwise borrow hairdrier from a girlfriend and get her to help you as well...
DREWDEN
PostPosted: Sat Nov 23, 2013 8:17 am Up
My standard keys work
206 2ltr Hdi glx 53 plate
PostPosted: Sat Nov 23, 2013 8:18 am Up
Excellent.
How does that help the OP?!
DREWDEN
PostPosted: Sat Nov 23, 2013 10:18 am Up
V9977 wrote:
Excellent.
your post wasn't showing, when i posted, meaning yours crept in before mine,
i was just trying to say standard key should work.
PostPosted: Sat Nov 23, 2013 10:30 am Up
DREWDEN wrote:
V9977 wrote:
Excellent.
Ah, OK.
Laughing
chopsim1
PostPosted: Sun Nov 24, 2013 2:50 am Up
All sorted. I went there this morning and it started. Must have had time to dry out.
Thanks for your replies anyway.
Thanks for reading
