Forums › The Car › 206 Problems › rad cooling fan |
Posted: Tue Dec 03, 2013 9:25 am |
the fan on my peugeot 206 1.1lx year 2000 only cuts in at high speed. should it not also run at low speed ?
I don't have the relays and resistor that are suspect on some models ?
fan at fault ?
Posted: Tue Dec 03, 2013 9:38 am |
Do you have aircon?
Posted: Tue Dec 03, 2013 12:16 pm |
nay, no aircon ?
Posted: Tue Dec 03, 2013 2:25 pm |
Pretty sure the two speed fan only came on models with air con. Someone will correct me if I'm wrong.
Posted: Tue Dec 03, 2013 4:51 pm |
Are there two relays? Sound like one or the wiring to one might be past its best.
Posted: Tue Dec 03, 2013 5:13 pm |
just checked with a mate, he said the rad fan on a1.1 lx are single speed. However my fan is past its best sounds like a bearing starting to go when operating.... can they be rebuiilt ?
