Online Now [242]:
Visitors: 241
Today: 47703
Total: 142861156
Forums › The Car › 206 Problems › Additive Tank
Additive Tank
206HdiGti
PostPosted: Mon Nov 18, 2013 5:54 am Up
2005 DV6
Hi all,
I had my car serviced at the weekend and had the additive tank topped up, as I've had the warning message for 2000 miles now.
It was up to the level when put back in and my mate (who did the servicing) has a snap on computer, with the ability to clear codes and reset counters.
It was all reset fine until...I went to use the car this morning and the warning message is back up. I know its full and I haven't got a DPF anyway so nothing terrible will happen, but is there a specific computer required to reset this counter?
PostPosted: Mon Nov 18, 2013 5:56 am Up
If the counters are reset, then there is another fault with the system.
What is the exact message? And if it thinks its empty it wont regenerate meaning the dpf will block
206HdiGti
PostPosted: Mon Nov 18, 2013 8:32 am Up
"Diesel Additive Level Minimum"
The DPF will block, but I haven't got one as it was replaced, so I'm not bothered about it.
PostPosted: Mon Nov 18, 2013 2:40 pm Up
So you have deleted it?! So why bother adding any fluid?!!
206HdiGti
PostPosted: Thu Nov 21, 2013 4:46 am Up
I want the message to go away
dicko79
PostPosted: Thu Nov 21, 2013 9:09 am Up
haven't you had it mapped out if you have had the dfp deleted?
PostPosted: Thu Nov 21, 2013 10:12 am Up
Have it remapped and deleted then
206HdiGti
PostPosted: Thu Nov 21, 2013 10:46 am Up
When I had my DPF removed and software done, I was told that the error message for the Eloys fluid will still come up and you cannot write that out of the software.
However, do I need to get a hold of a Peugeot Planet? hardware to reset the counter?
sweeney
PostPosted: Sat Dec 14, 2013 5:10 pm Up
i have had the same problem the message stilll there, have you had your sorted yet
