Posted: Sat Dec 14, 2013 3:40 pm |
hi all, i've noticed i have a leaking injector, is it just the copper washer that needs replacing or is it worth replacing all of the seals while the injector is out.
thanks in advance
Posted: Sun Dec 15, 2013 3:16 pm |
If your asking this, i advice you pay someone to do it
As you have to have a injector cleaner tool, as a slight bit of ingress down were the injector seats will make it leak again. I always advise doing four if the carbon level is touching another injector or two or more are leaking
Plus also you have to be meticulously clean when doing the job
| Team Impossible Possible
Posted: Sun Dec 15, 2013 6:11 pm |
just done one on a 1.4hdi, managed to borrow a seat dressing/cutting tool off local mechanic!
