Latest: Mr-Koekwaus
Overall: 17125
Online Now [32]:
Visitors: 31
Today: 11443
Total: 99981365
Forums › The Car › 206 Problems › Rear Demister
Rear Demister
lmilligan
PostPosted: Sun Dec 15, 2013 2:05 pm Up
Hi,
Just wondering if anyone can answer this, haven't been able to find this on the site. Where does the click noise come from when you put the rear demister on? Is it a relay of some sort and can it be replaced if so? Got a problem with a 206 where you go to turn on the rear demister and there is no audible click noise and the icon no longer comes up on the cc screen.
PostPosted: Sun Dec 15, 2013 2:32 pm Up
Fuse? F10 in the passenger compartment fuse box, 40 amp
lmilligan
PostPosted: Sun Dec 15, 2013 2:35 pm Up
Unfortunately checked that, should have stated that sorry. Tried a working CC unit from my own car and nothing. Just missing that click noise.
PostPosted: Sun Dec 15, 2013 2:49 pm Up
Apart from a bad connection somewhere, the only other thing I can think off is a problem in the BSI. Have you tried a BSI reset?
Edit. Fuse 18 in the engine bay feeds the control panel. Not sure if your blowers are working so might be worth checking that to make sure the panel is getting power.
PostPosted: Sun Dec 15, 2013 5:05 pm Up
If the demister circuit is broken, surely you wont get the click.
lmilligan
PostPosted: Tue Dec 17, 2013 9:06 am Up
Thanks for the diagram macca, will have to have a look into the wiring
DREWDEN
PostPosted: Tue Dec 17, 2013 4:46 pm Up
The clicking noise on mine when i activate the switch comes from the fuse box under the steering wheel.
The relay that clicks is a timer relay and operates for 12 mins or so then switches off, to stop drain on the battery.
I also presume your mirrors demisters are not working either, meaning not getting warm, as the switch operates both rear screen and mirrors, may be worth checking the wiring.
206 2ltr Hdi glx 53 plate
