Latest: heikkisj
Overall: 17126
Online Now [399]:
Visitors: 397
Bots: 2
Today: 36959
Total: 100369914
Forums › The Car › 206 Problems › Washer fluid not coming out
ed2k12
PostPosted: Tue Apr 02, 2013 6:10 pm Up
I cant get any washer fluid to come out of the bottle and onto my windscreen
I pull the washer stalk but no sound is made, I have taken it to a garage and they have said that the pump itself is fine and the fuse was blown however with a new fuse it still fails to work.
They suggested a electronic problem.
Anyone know the problem, fix or any info to help?
iainlovatt
PostPosted: Wed Apr 03, 2013 2:51 am Up
dead motor? Its located on the washer bottle! Try a different fuse though and make sure it been put back in the right location!
(My Garage)
Mr-Tigger
PostPosted: Wed Apr 03, 2013 5:12 am Up
def check the fuse,and that its inserted properly,mine has a weird ability of removing itself from the slot on the washer jet for some reason
PostPosted: Wed Apr 03, 2013 12:52 pm Up
Probably the motor is dead,best way is to take the wheel liner out,check the plug if there is voltage when someone press it,if not then the fuse is blown
clintyfitz
PostPosted: Fri Dec 20, 2013 11:09 am Up
I am currently having this problem. The pipes and jets are clear, I have changed the pump and the fuse, the washer still doesn't work.
Could there be an earth fault or something else? I am at a loss to figure out what it is.
mtempsch
PostPosted: Fri Dec 20, 2013 2:50 pm Up
Get to the plug on the motor and disconnect. Voltmeter to the plug:
Code::
(Trying to use indentation for conditional testing dependent on y/n answers.)
12V? No?  -> Measure positive lead against a good ground. 12V then?
                  Yes?->bad ground connection.
                   No?-> bad positive feed.
                       Check continuity on the ground wire to good earth to
                       check the ground wire as well (so there's not a double
                        fault).
Yes? -> Is the motor known (tested) good? If not, test it with temp wires
from the/a battery. If if it works then you might have a high resistance
connection in the wiring (ie measures good 12V with a high resistance
load like the meter, but prevents the motor from drawing the much higher
current it needs.
Other then that I'm out of theories...
Silvermetallic 2004 206 RC
