Latest: sparrowdclxvi
Overall: 17139
Online Now [73]:
Visitors: 73
Today: 7770
Total: 112662790
Forums › The Car › 206 Talk › Clutch Change in North West
rlees85
PostPosted: Sun Dec 22, 2013 7:15 am Up
Just wondered if anyone knew a decent mechanic who could do a reasonably priced clutch change on a 2.0 HDI? Basically someone like KrisB but around the North West ?
Also which is a decent clutch kit to buy? (Uprated ideally or decent standard)
All the mechanics around here I know of will charge an arm and a leg for a crappy job. Would do it myself if I had the tools and time :/
Thanks !
PostPosted: Sun Dec 22, 2013 7:41 am Up
Thanks !
Cartoonhead aka Larry, is top notch. Done loads of work on both my cars and I highly rate him. He is based in Middleton. Give him a shout.
PostPosted: Sun Dec 22, 2013 7:47 am Up
Crappy job? How can they do a bad job of a clutch change?
ukskater01
PostPosted: Sun Dec 22, 2013 11:08 am Up
I've seen clutches fitted the wrong way round even though it has the engine side stamped on it!
PostPosted: Sun Dec 22, 2013 1:39 pm Up
Thanks !
+1
rlees85
PostPosted: Sun Dec 22, 2013 3:27 pm Up
Cheers ! Hope he doesn't mind a PM coming his way after the xmas period then! Smile
commandosqueak
PostPosted: Sun Dec 22, 2013 7:01 pm Up
have a look at the mechanic thread thats been started may help you Smile
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
rlees85
PostPosted: Wed Jan 08, 2014 5:39 pm Up
cartoonhead (Larry) did the clutch (and a couple of other odd jobs). All sorted now, top lad, really knows his stuff!
