Latest: dreyfalon
Overall: 17121
Online Now [170]:
Visitors: 169
Today: 29336
Total: 97709894
Forums › The Car › 206 Talk › compression test 1.4 8v petrol
bikesforme
PostPosted: Sun Dec 22, 2013 1:36 pm Up
Can anyone tell me what the compression should be on a 2001 1.4 8v petrol engine. Mine read no1 70, no2 75, no3 60, no4 60. When put a teaspoon of oil down each bore they read, no1 105, no2 100, no3 100, no4 100.
PostPosted: Sun Dec 22, 2013 4:00 pm Up
Was the throttle fully open on the test?
As it seems all low. But they are within 10 percent so technically its classified as okay
commandosqueak
PostPosted: Sun Dec 22, 2013 6:25 pm Up
The compression ration is 10.5:1. Pug never disclosed the compression figures. as long as all is within 2 bars any more indicates a fault. my manual says as a GUIDE any pressure below 10 bars can be considered less than healthy Compression should build up quickly
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
bikesforme
PostPosted: Mon Dec 23, 2013 12:20 am Up
Throttle was fully open and they reached the max reading stright away on first turn of the key. My haynes manual says 10 bar which is double my readings, i know they are all well within 2 bar of each other, but the readings seem so low.
commandosqueak
PostPosted: Mon Dec 23, 2013 5:43 am Up
That was where i got my information from Smile personally i would say if all the readings are consistent then dont worry
