Posted: Sun Dec 22, 2013 4:58 pm |
hi there all when driving my 206 with 4 people in the windows steam up that bad even with the blower on i cant hardly c out the rear and side widows the blower is fine and works im wondering if this is a common fault with them because they r a small car plus i aint had it long and my last car was a 306 and it was never this bad
Posted: Sun Dec 22, 2013 5:04 pm |
Use the A/C if you have it.
Posted: Sun Dec 22, 2013 5:12 pm |
hi steve yes it has a/c bt i thought u use that in the summer not winter or does it work better on warm air settings 2 ?
Posted: Sun Dec 22, 2013 5:25 pm |
Wonder if other people will interprit what gave me a giggle after i have just read it.
| 206 2ltr Hdi glx 53 plate | |
Posted: Sun Dec 22, 2013 5:48 pm |
On a serious note, if it has the climate control, turn on the Automatic Visibility programme button, the bottom, left next to the auto button.
gets rid of humidity very quickly.
Posted: Sun Dec 22, 2013 6:10 pm |
cold air on ac clears the window very quickly failing that i got some anti fog stuff from halfords and have used it on all my cars. very good stuff but has to be applied every time you clean the windows
| 2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey | |
Posted: Sun Dec 22, 2013 7:08 pm |
Open the back windows slightly.
The steam/condensation on you windows is caused by moisture in the air. People generate moisture,
Warm air carries moisture cold air can't hense the condensation.
Open windows to allow the warm air to carry the moisture out side untill car is dry inside. You will need to carry on doing this as people generate moisture by breathing constantly.
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Sun Dec 22, 2013 10:46 pm |
And having the windows clean on the inside helps a bit. Dirty windows tend to get foggy more easily.
| 306 S16, 306 GTI-6, 605 SV24, 205 GTI-6, 2x405 Mi16, VW T3 1.9TD/AAZ, Audi TT mk2 3.2 quattro, Audi A6 2.7 biturbo quattro | |
Posted: Mon Dec 23, 2013 4:03 pm |
cheers guys have taken on board wot u have said will give it a try thanks all
Posted: Mon Dec 23, 2013 4:16 pm |
Also set your circulation system to bring in air from the outside. As above there is a lot of moisture in peoples breath. If you don't replenish the air with fresh air from the outside that moisture from their breath builds up more and more.
The reason aircon helps demist is that the moisture in the the air condenses on the aircon unit because when the aircon is on that is very, very cold thus removing moisture from the air. Aircon on and heater set to hottest setting means you have very dry warm air inside the car. Perfect for removing condensation.
Other things to check:-
Damp carpets from any leak?
Mates spilt a drink in the car?
Clogged or damp pollen filter?
If you have a Roland Garos sun roof then with the inner blind pulled across moisture settles on the inside of the glass of the sun roof. When air circulates it picks this up and that then settles on the side windows. Pull the inner blind back and wipe the sun roof dry. This caused havoc with my daughter's car before we found out what was happening.
Finally, with this very, very wet atmosphere at the moment with 4 adults in the car it might struggle a little at the moment.
Posted: Mon Dec 23, 2013 6:33 pm |
My car fogs up badly too. My passengers don't like it when I ask them to stop breathing......I'm gonna try some of the suggestions now because I'm running out of friends.
Posted: Tue Dec 24, 2013 6:18 am |
as said above just turn the A/C on even with temp set to warm it will clear your windows.
Posted: Tue Dec 24, 2013 6:52 am |
try changing the pollen filter
Posted: Tue Dec 24, 2013 10:54 am |
Yes, as my post, a new pollen filter can make a big difference.
Posted: Fri Dec 27, 2013 1:45 pm |
a/con on is the answer, but once you start to use the air con to clear the windows it becomes the only way to clean them until the car gets a through flow of fresh air like in the summer.
