Posted: Sun Dec 29, 2013 5:07 pm |
Bosch: £55
Valeo: £90 (if I can remember)
If these do the same job would bosch still be good for a coil pack? Or you guys prefer valeo at all?
Posted: Sun Dec 29, 2013 6:53 pm |
Either will be fine. Just avoid Bougicord
Posted: Mon Dec 30, 2013 1:23 am |
macca1411 wrote: |
Either will be fine. Just avoid Bougicord |
No Bougicord is fine, Sagem were the one's to avoid but that was ages ago..
Posted: Mon Dec 30, 2013 4:21 am |
Yeah avoid Sagem like the plague, nasty things those ones!
Bougicord was the higher end/better quality 'replacement' for the failing Sagem ones IRRC. Valeo ones are a good choice too, I've never seen a Bosch one myself..
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Mon Dec 30, 2013 7:44 am |
Ste wrote: |
Bougicord was the higher end/better quality 'replacement' for the failing Sagem ones IRRC. Valeo ones are a good choice too, I've never seen a Bosch one myself.. |
Hm, BOSCH normally are decent for most stuff but I got a few stuff on the car that's Valeo but none of its failed yet. So I'll probably just go for the Valeo one.
Thanks. ☺️
Posted: Mon Dec 30, 2013 11:37 am |
Is yours the black or grey plug one mate?
www.ebay.co.uk/itm/PEU...53f8217e52
If its black thats a genuine bougicord and they accepted £20 plus postage when i offered when i brought one.
Posted: Mon Dec 30, 2013 11:49 am |
My Euro Car Parts coil pack came in a Valeo box but it was a Sagem inside!
Posted: Mon Dec 30, 2013 12:24 pm |
Edward wrote: |
My Euro Car Parts coil pack came in a Valeo box but it was a Sagem inside! |
Will the coil pack have the brand on it?
Posted: Mon Dec 30, 2013 12:27 pm |
Yes they should do. Mine has it near the connector.
Posted: Mon Dec 30, 2013 4:17 pm |
I'm still running the original Bougicord coilpack (+cap mod) from 2001..
Do you recon I should replace it?
Posted: Tue Dec 31, 2013 2:07 am |
Will she run slightly better with a new coilpack?
Posted: Thu Jan 02, 2014 1:42 pm |
I bet she will..
