Online Now [740]:
Visitors: 739
Today: 221497
Total: 150054078
Forums › The Car › 206 Problems › snapped suspension spring interchangeable?
adamb
PostPosted: Sat Dec 28, 2013 3:47 pm Up
Right I heard a noise coming from my front suspension and checked it out. I have a snapped suspension spring coil.
My question is are Citroen c2 springs the same as I have a couple knocking about from my old car.
If not does anyone have 1 for sale near Mansfield?
Cheers
Adam
1999 206 1.6 Roland garros gone
02 2.0 d-turbo with tuning box Smile
PostPosted: Sat Dec 28, 2013 3:51 pm Up
Is it possible to bodge? Most likely yes
Should you? No
Just get the correct one for the car - it ideally needs to be off the same model / engine size to stop one side being at a different height
adamb
PostPosted: Sat Dec 28, 2013 3:53 pm Up
I'm sure there are different springs for my engine. Its the 2.0hdi 8v engine.
Sure I saw 1.4 1.6 2.0hdi are the same spring?
Just been looking at oics and I don't think they are the same unfortunately.
So does anyone local have a spare? Lol
PostPosted: Sat Dec 28, 2013 4:03 pm Up
I assume several engines use the same springs but I wouldn't be able to say which ones
mjsroofing
PostPosted: Sat Dec 28, 2013 10:22 pm Up
When buying the springs they will be listed to fit several cars and they will fit BUT they might have a different load rateing to yours so as long as you change the pair you should be OK.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
