Posted: Thu May 31, 2012 8:08 am |
Got a 02 2.0 HDi
Have to put a new cluster on, Iv'e got my hands on one off a Gti HDi
Everything works ok but it has the oil temp guage which mine dosn't
Anybody know if there's a way to get that working on my 2.0 HDi
mask0017
Posted: Thu May 31, 2012 8:27 am |
Think it just needs a BSI tweak if I remember correctly.
Posted: Thu May 31, 2012 8:45 am |
| mask0017 wrote: |
Got a 02 2.0 HDi
mask0017 |
You simply need to fit the oil temp sensor & tweak the BSI configuration set up which needs Peugeot Planet.
Hope the replacement cluster has a LOWER mileage on it ELSE you will trigger the anti clocking system
Then again if its already fitted it would be to late now
Posted: Thu May 31, 2012 8:54 am |
Ye the mileage on new one was lower and I have Peugeot Planet.
So I need to change the oil sensor to one off a GTi then
And go into the BSi config in Planet
mask0017
Posted: Thu May 31, 2012 10:00 am |
| mask0017 wrote: |
mask0017 |
The 2.0 HDI uses a dual level & temp probe.
The only oil level probe I can see listed for the 206 2.0 HDI on Peugeot service box says it has both level & temp functions.
Cross your fingers, fire up Peugeot Planet & tweak that BSI configuration & you MAY be lucky.
Posted: Thu May 31, 2012 11:15 am |
yip your spot on
just done peugeot planet (took a while to find the right bit) switched the oil temp to present working a treat.
Many thanks for help Guys.
mask0017
Posted: Thu May 31, 2012 11:19 am |
Nice one
Posted: Thu May 31, 2012 11:26 am |
Trade Rating: +59
| MrBSI wrote: |
Nice one  |
+1, always wee hidden parts you never know about until you have a tinker.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Thu May 31, 2012 11:35 am |
| Lecktorious wrote: |
| MrBSI wrote: |
Nice one  |
+1, always wee hidden parts you never know about until you have a tinker. |
I didnt know the 2.0 HDI only came fitted with the dual function oil probe untill I fired up Service Box
Posted: Mon Jan 06, 2014 2:29 pm |
Just bought the same dials myself for my 2.0 HDi do you remember where abouts in Peugeot Planet you found the setting, Thanks.
