Posted: Wed Dec 25, 2013 9:15 pm |
could someone please tell me if the JANSPEED backbox for the gti180 fits the standard system?
reason i ask is i have a full SCORPION system but would like to change the backbox
Posted: Thu Dec 26, 2013 12:24 am |
Janspeed backbox only fit to Janspeed cat back
Posted: Thu Jan 02, 2014 5:27 pm |
do u know why?
Posted: Tue Jan 07, 2014 11:03 am |
Don't know why that would be but on my 106 gti it fitted the standard center fine.
Posted: Wed Jan 08, 2014 3:38 am |
I dont think the janspeed would fit the standard centre pipe because the standard outer diameter is around 60mm and the janspeed outer diameter is 62mm or 63mm ?? But as far as im aware the scorpion is the same diameter so you could fit the janspeed back box to the scorpion centre section as long as the end of the centre section is in the same place on the scorpion as it is on the janspeed.... if it isnt you may have to change the hanger on the janspeed back box to line the tip up correctly with the cut out in your bumper
