Latest: Mr-Koekwaus
Overall: 17125
Online Now [306]:
Visitors: 305
Today: 45987
Total: 99740218
Forums › The Car › 206 Problems › advice on led sidelights/number plate lights.
gizmothedog
PostPosted: Thu Jan 02, 2014 2:59 pm Up
I had a sidelight out on my 206 so I decided to buy some led sidelights from ebay (10 for £2 delivered) worth a shot I thought
I took out the old bulbs and fitted the new ones. I now have 1 number plate light working and none of the others. so I stood scratching my head.... Confused
Next step...try to find a fuse...must have blown one
Logged on to 206 info to find out which one it is. Nope no fuse for side lights. I will disconnect the battery and do a reset. Did this twice and still nothing.
Right ...have a think while im having a cuppa.
Put multimeter on and reading 14v...eh???? power but no light?
Then I read that it might be the thickness of the wire on the led not connecting to the socket, so I stripped some cable and wedged some into the led and refitted. VOILA!!! ALL LIT UP.
I now have nice white sidelights, number plate lights and interior light. Laughing
So I thought id put it on here incase anyone else has the same trouble and doesn't want to waste nearly two hours doing a 5 min job...
commandosqueak
PostPosted: Thu Jan 02, 2014 3:09 pm Up
some thing else worth noting is led's only have a single polarity, make sure the bulbs are in the correct way. i had the same problem and i just turned the bulb round and it worked
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
gizmothedog
PostPosted: Thu Jan 02, 2014 3:13 pm Up
tried that aswell. made no difference to mine as the wires were that thin on the LED's they weren't connecting.
DanT
PostPosted: Thu Jan 02, 2014 6:19 pm Up
I had a whole load of those el cheapo led sidelight bulbs once, after about a month they start flickering in my experience and then give up completely, just went back to bulbs after that can get white looking ones easy enough anyway.
commandosqueak
PostPosted: Thu Jan 02, 2014 6:33 pm Up
saying that mine have started flickering, hoping to get new lights soon so cant be bothered to change them unless they go completely
standardgt180
PostPosted: Wed Jan 08, 2014 8:19 am Up
mine flicker ??? looks like there haing a disco in the car in font
