Latest: lio94
Overall: 17181
Online Now [218]:
Visitors: 217
Today: 52396
Total: 142002919
Forums › The Car › Request a how-to › Brake Bleeding 180
Brake Bleeding 180
Forum IndexRequest a how-to
bashyy1
PostPosted: Thu Jan 09, 2014 4:17 pm Reply with quote Up
Hi,
I've looked about on the forum and can't find a how to for bleeding the brakes at all.
Can anyone tell me how its done at all, my brake pedals quite spongey, pads and discs looks fine to me, so think there's air in the system?
Aegean Blue Gti 180.
Project Thread
omega
PostPosted: Thu Jan 09, 2014 4:45 pm Reply with quote Up
the normal way is to start bleeding the caliper furthest away from the master cylinder then work round.
1245678
Conners300983
PostPosted: Thu Jan 09, 2014 4:46 pm Reply with quote Up
If there is air in the system id be looking to find the cause as it should be a sealed system. Look for any small fluid leaks, usually found on perished rubber hoses. I'd definitely recommend a gunsons eezi bleed to bleed the brakes. Makes the whole operation much easier, it attaches to the brake reservoir, and the spare wheel for pressure, then it's a simple case of cracking each bleed nipple (found on the calliper) in turn, starting with the furthest wheel from the reservoir until clean bubble free fluid emerges. Has your brake fluid been changed recently? as it's far more likely to be moisture in the fluid if not.
bashyy1
PostPosted: Thu Jan 09, 2014 5:17 pm Reply with quote Up
The brake fluid hasn't ever been changed, well I haven't done it since I've had it.
The pedals just soft and brakes grind ever so slightly at slow speeds.
I think i'll need more of a step by step guide as I have no idea where to start or what I'll need etc?
Project Thread
AndrewR2211
PostPosted: Thu Jan 09, 2014 5:39 pm Reply with quote Up
This would be a helpful guide.
My 206 Sport
Conners300983
PostPosted: Fri Jan 10, 2014 1:46 am Reply with quote Up
If I get time I'll try and knock a how to with a couple of pics up over the weekend. It's not a difficult job at all and there's a few different methods of actually doing it. It's a pretty generic procedure though so maybe try googling "how to bleed brakes". I'd definitely consider new fluid as old fluid absorbs moisture and over time will present symptoms like you describe.
PostPosted: Fri Jan 10, 2014 6:54 am Reply with quote Up
Have a read of this thread and it might give you a few pointers as to the equipment needed.
Kale
PostPosted: Fri Jan 10, 2014 9:25 am Reply with quote Up
I bleeded the brake system on a RC (GTI180) which was completely drained from brake fluid (because of ABS/ESP unit replacement) using a brake bleeder which creates vacuum on the bleed nipple and it went fine. After the first round around the car there was a little amount of air left and after a second try it was all gone.
So I say PP2000 isn't necessary. Although I have one but didn't have my computer with me at that time Very Happy
It takes a little more work and a little more brake fluid but it is possible.
306 S16, 306 GTI-6, 605 SV24, 205 GTI-6, 2x405 Mi16, VW T3 1.9TD/AAZ, Audi TT mk2 3.2 quattro, Audi A6 2.7 biturbo quattro
Conners300983
PostPosted: Fri Jan 10, 2014 10:56 am Reply with quote Up
My bad , i wasn't aware the software was needed. I'd still say with a gunsons eezi bleed it would be possible without though. They pressurise the system forcing any air out. I can honestly say its worked every time for me on many other cars (with and without abs) and was well worth the £16 investment
Kale
PostPosted: Fri Jan 10, 2014 11:57 am Reply with quote Up
Just to add to my last reply, I did take the car for a spin between the attempts to bleed the brakes. If there was some air trapped to the ABS unit at first, it probably moved towards the calipers while driving because after the second try they were perfect..
PostPosted: Fri Jan 10, 2014 12:16 pm Reply with quote Up
It's better to have the PP2000 ,as it will make this job easier,and it tells you which wheel to bleed,and that prevent any damage to the ABS pump :),this is actually a 2 ppl job,if you don't anything to pressure the system.
Kale
PostPosted: Fri Jan 10, 2014 5:51 pm Reply with quote Up
Yeah, I have PP2000, but didn't have it with me at the time I was bleeding the brakes. And I was doing it by myself with a vacuum brake bleeder.
I once checked that bleeding routine on PP2000.. it takes forever to get through Very Happy and you can't back up from it once it's started.
bashyy1
PostPosted: Sat Jan 11, 2014 11:47 am Reply with quote Up
Guys, I'm not sure where to start... my brakes are just not as responsive as they were a few weeks ago, pedal has to pushed further and harder.
To me the pads look OK (the rears a lot more worn that the fronts) through the wheel but I'm no mechanic, what can I try, shall i just change them to rule them out of a possible cause?
Any help appreciated
Project Thread
Conners300983
PostPosted: Sat Jan 11, 2014 12:23 pm Reply with quote Up
If your saying there's a bit of meat left on the pads, personally I'd start with a fluid change, maybe take it to your local garage if your not confident doing it yourself, a competent mechanic should do it in half an hour so it shouldn't be expensive. Is there any groves in your discs? This can often be a tell tale sign your pads are shot.
bashyy1
PostPosted: Sat Jan 11, 2014 1:05 pm Reply with quote Up
Okay thanks mate
I'd like to fix it myself really, I just have a hard time deciding what things to check/change first.
When I rub my fingers over the rear discs they don't feel smooth like the fronts do. It's like a very slight bumpy/rough texture. Does that mean they need replacing?
Project Thread
  Quick Reply
Username:
Message:
Quote the last message
