Forums › The Car › 206 Talk › Air vents on bonnet of 180 |
Posted: Sun Jan 12, 2014 11:57 am |
Hi all,
Do the air vents on the bonnet serve as any purpose?
I can see huge space underneath the bonnet on the drivers side but wasn't sure if that leads to anywhere?
Any info would be great!
Posted: Sun Jan 12, 2014 11:58 am |
Yep, pollen filter for the cabin lives inside there.
Posted: Sun Jan 12, 2014 12:39 pm |
Put the heater on full and put your hand over the bonnet vents.
Posted: Sun Jan 12, 2014 2:41 pm |
As said, they are so the air can get to the pollen filter and into the cabin. All i know is, the shape of the space under the bonnet really annoyed me when replacing my cambelt!
