Posted: Thu Jan 30, 2014 2:16 am |
Hi Guys,
Got what I believe to be a problem
When im driving down the A46 and I get to 70mph there seems to be a rumbling from the passenger side area at the front. Now when I take my foot off the accelerator the rumbling stops. Its only when I start to accelerate that the rumbling starts again. I thought it was only 5th gear that it did it in so I tried dropping into 4th and yet it still does it but you cant hear it much as the car is doing a fair few revs... obviously.
Does anyone think they know what this might be.
Its only started since I put my mudflaps on the car and also since I had a slide and my car enjoyed the sight of a kerb :/
Hope you guys can help.
Luke
Posted: Thu Jan 30, 2014 4:12 am |
rumbling around the wheel area usually suggests a wheel bearing needs changing .
Posted: Thu Jan 30, 2014 5:09 am |
Trade Rating: +13
So you kerbed the car at speed and have not had the suspension, tracking and balance checked!?!?
Posted: Thu Jan 30, 2014 5:30 am |
I didnt hit the kerb at speed. I hit that at literally 5-10 mph in the ice. I havent had time to check it tbh.
It is concerning me dont get me wrong. It happened just over a week and a half ago now :/
Posted: Thu Jan 30, 2014 1:17 pm |
The easiest way to check, is jack up the front wheels, and get someone to see what the rumbleing is, while you go up and down the gears.
| 206 2ltr Hdi glx 53 plate | |
Posted: Thu Jan 30, 2014 1:21 pm |
Trade Rating: +13
Tbh if you don't have the knowledge or time get it to a garage.
Posted: Thu Jan 30, 2014 1:41 pm |
jack it up spin wheel with hand check for any grinding noises etc, check for play in the wheel at same time.
Posted: Fri Jan 31, 2014 2:10 am |
Yeah select-a-tyre are doing free track and balance check so gonna go there saturday
Posted: Fri Jan 31, 2014 7:43 am |
Take the mud flaps off and see if the noise goes.
Posted: Sat Feb 01, 2014 6:18 pm |
**Any Input Welcome!** iv got a similar rumbling noise, (iv sorted 1/2 of it) only when going straight and turning right. i also thought it was th wheel bearing, but after having th front left to pieces th bearing seems to spin smooth (could still be naff tho?!) also th wheel has NO play in it watsoever (when "shaken") !!
So. . . . . . i also had a suggestion it was th gearbox, so i changed that & 1/2 of th noise went away (th slight grinding in 1st & 2nd) but i still have a grumbling coming from th front left of th car!
your thoughts on: im thinking it could be;
1 - th drive shaft is nakered either side or both?
2 - th wheel bearing is stubborn & badtempered (f***%#!)
3 - th new gearbox is also (as above) f***%#! (i think this is unlikly as th noise persists both under power and clutch down)
4 - we buy any car offered me £350 cut my losses and take it!
5 - something else. . . . ?. . . .
thanks for reading my boring problem post, plz leave me feedback!
Posted: Sun Feb 02, 2014 3:30 am |
| Cptn.Sparrow wrote: |
thanks for reading my boring problem post, plz leave me feedback! |
Most of the time if its when turning its a drive shaft. More noticeable when on full lock.
Posted: Sun Feb 02, 2014 7:59 am |
yea it wa f****%@ driveshaft CV joint!!! (how easy wa that, feel like a rate plank!) cheers anyway!
