Posted: Mon Jan 27, 2014 10:15 am |
Hi, I bought a Peugeot 206 1.4 '02 automatic recently, the temp gauge is stuck half way when the car is not running & flickers, jumps to red as soon as car is started & fan kicks in soon as. I have just paid £600 at a garage to fix it but still is the same, it's had new thermostat, temp switch & other things but now been told that it could be a fault with the ecu, could anyone help this damsel in distress please ![Crying or Very sad Crying or Very sad](images/smiles/icon_cry.gif)
| | ![](images/spacer.gif) |
Posted: Mon Jan 27, 2014 10:32 am |
Was it the coolant temperature sensor they changed?
Posted: Mon Jan 27, 2014 10:34 am |
Hi, all I know is it's the green sensor next to the blue 1 & on my bill it just says temp switch ?
Posted: Mon Jan 27, 2014 10:37 am |
A quick scan of the ecu should show the fault.
Where are you based?
Posted: Mon Jan 27, 2014 10:41 am |
I'm Sheffield & the garage said they had an auto electrician test it & it showed a fault on the ecu but got no codes for me I feel I'm being ripped off & just told this to take my car back to them at more cost to me ?
Posted: Mon Jan 27, 2014 10:43 am |
I've been reading the threads & some say there are 3 sensors others say 2 & also could be a dash wiring or sensor fault
Posted: Mon Jan 27, 2014 11:05 am |
Check on the Pp2000 map. There maybe a member nearby who can offer assistance. There are some dodgy garages out there
Posted: Mon Jan 27, 2014 11:11 am |
Posted: Mon Jan 27, 2014 11:18 am |
Thanks for your help & replies I'm new to this & blonde ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Mon Jan 27, 2014 11:53 am |
Well thats no excuse for a garage ripping you off
Posted: Mon Jan 27, 2014 7:36 pm |
mattymj wrote: |
Not necessarily.
'Bit more detail needed and history of the problem, esp if a professional garage has already worked on it.
