Latest: sparrowdclxvi
Overall: 17139
Online Now [138]:
Visitors: 137
Today: 36457
Total: 113645232
Forums › The Car › 206 Problems › Massive problem
Massive problem
Davegoulding
PostPosted: Sun Feb 23, 2014 4:10 pm Up
Hi guys and girls new to this but I am in need of some advice. I have a 206 hdi gti 110 I split the block and then replaced the engine and it said dpf needs regenerating but I steam cleaned it a was advised it was running sweet for a few days. I went out to it the other day as it still not on the road as the emissions are through the roof and it was on tick over then just died now it's not doing anything there is no power what so ever and it was running fine it was as if I turned it off but now no lights come on and whilst I am on the subject of dpf how can I bye pass it please. Many thanks dave
PostPosted: Sun Feb 23, 2014 4:35 pm Up
Is your battery flat?
Davegoulding
PostPosted: Sun Feb 23, 2014 4:49 pm Up
No brand new it was running on my drive and it was like I had turned it off but I hadn't touched it
Davegoulding
PostPosted: Sun Feb 23, 2014 4:50 pm Up
When I put the key in the ignition no lights appear nothing happens
20Drift
PostPosted: Sun Feb 23, 2014 5:10 pm Up
Check your battery connections and engine ground to gearbox.
Try a BSI reboot to see if that solves it.
Davegoulding
PostPosted: Sun Feb 23, 2014 8:35 pm Up
Will give it ago and let u know thank u
Davegoulding
PostPosted: Mon Feb 24, 2014 5:10 am Up
Does anyone know what the code pp2000 is please as that is a fault that comes up on my reader
PostPosted: Mon Feb 24, 2014 5:20 am Up
PP2000 is the dealer diagnostic software.
A Powertrain DTC will be P followed by 4 numbers.
societydweller
PostPosted: Sun Mar 16, 2014 3:43 am Up
any update on this problem ?
PostPosted: Sun Mar 16, 2014 5:00 am Up
Lads at my local garage sent one of these on the slow boat to China via Newport the other day, cost to repair the engine wasn't worth it & the owner agreed Cool
Another DV6TED4 in the shredder Laughing
