Posted: Tue Feb 04, 2014 12:48 pm |
Hi
I am looking to buy a replacement Lambda for my 2005 1.4cc verve.
The existing one has the numbers 9636968380 & A341 on it.
I have been advised by a lambda supplier to purchase a 1628TH but this number appear's very hard to find and when found they are a lot more expensive than the other ones.
Is this correct or has it been superseded by a different number?
Neil
Posted: Tue Feb 04, 2014 1:01 pm |
I got mine from here mainly because he's only down the road from me.
Have you checked on servicebox which one is already fitted. If you PM me last 8 of your VIN I can have a look and give you the part number which should be similar to 1638TH. The other 2 numbers look more like manufacturer reference numbers.
The price varies depending if its a pre or post CAT sensor
Posted: Tue Feb 04, 2014 1:13 pm |
Hi Thanks for offering to help
Vin No 44852003
Looking for the post cat lambda
Thanks neil
Posted: Tue Feb 04, 2014 1:26 pm |
1628NY £182.30
FYI pre cat sensor 1618R0 £146.39
Posted: Tue Feb 04, 2014 2:09 pm |
Many thanks
Neil
Posted: Tue Feb 04, 2014 2:45 pm |
they are not cheap are they?
my 2ltr one was 70 pounds.
Posted: Thu Feb 27, 2014 5:11 am |
Just got my 2005 1.4cc verve back from my local Peugeot specialist after having a new genuine Pre cat Lambda sensor fitted because the cheaper after market one was not doing the job properly and I was having terrible problems when the engine was cold.
Anyway he suggested that I should adjust the valve clearances when I had a spare hour or two.
Question is there an "HOW TO" on the site with instructions and what are the gaps meant to be?
Neil
