Online Now [1281]:
Visitors: 1280
Today: 76711
Total: 149482574
Forums › The Car › 206 Talk › ph1 to ph2 light conversion
Forum Index › 206 Talk
ct-xsi
PostPosted: Thu Feb 06, 2014 4:04 pm Up
Right to be honest ive been looking at the guides and am struggling to get my head around this...
Ive been thinking though.. obviously the h4 plug has 3 wires... earth, live for dipped and live for full beam...
If I was to get a plug that clicked onto the ph2 lights (the 3 pin plug) and put spade connectors onto the ends and provided I got the earth right... im thinking that it would then work so that it would light up on bulb on dipped and then one bulb for full?
Am I right?
DanT
PostPosted: Thu Feb 06, 2014 5:37 pm Up
Erm well not quite, if you're interested in doing it you can use this guide which is pretty good!
206info.co.uk/Forums/v...51124.html
ct-xsi
PostPosted: Fri Feb 07, 2014 5:27 am Up
All sorted...
thanks for the reply though Dan...
turns out my car had the ph1 and ph2 wiring plugs aready in so jobs a good un Smile
\'02 206 XSi
coachtripper
PostPosted: Fri Feb 07, 2014 3:11 pm Up
And speaking of headlights just missed out on a brand fire new pair of P2 genuine headlights, rear lights and honeycomb grill and all for a twenty spot. Nothing wrong with mine its just i love to bag a bargain but obviously not this time eh Sad
Leegsi
PostPosted: Sun Feb 16, 2014 10:53 am Up
But when you switch to main beam the dip go out.
gazza82
PostPosted: Sun Feb 16, 2014 1:22 pm Up
Your wiring needs to be modified ... one options is two relays to keep both on at same time (as I did to mine!)
PostPosted: Sun Feb 16, 2014 2:00 pm Up
Or get an indicator stalk from a gti etc and will do the job Wink Wink
