Online Now [1012]:
Visitors: 1011
Today: 313851
Total: 152341917
Forums › The Car › 206 Problems › Do i need a new circuit chip???
Capone
PostPosted: Mon Feb 17, 2014 3:49 pm Up
Hi,my fob was missing the rubber cover over the lock button so being lazy I have been just clicking the little black one on the circuit chip, but the other night I went to lock it and seen it had fallen off.Can I just buy a new circuit chip and just reprogram it? any help would be much appreciated.
PostPosted: Mon Feb 17, 2014 4:13 pm Up
Well you can do that,but it has to match the last letter on yours like "C" or what ever you have,and reprogram it with PP2000,and you need to have the 4 digits security code.
BUT.....
You can save all the hassle,by having the replacement kit (comes 2 buttons),and you can replace the one is faulty,and all will be back great,and with a new fob ofcourse.
PostPosted: Mon Feb 17, 2014 4:15 pm Up
Click on this,and choose Smile
www.ebay.co.uk/sch/i.h...t&_sacat=0
Capone
PostPosted: Tue Feb 18, 2014 2:19 pm Up
Timon2210 wrote:
BUT.....
Thanks for the reply, so will that new button work straight away once connected to the circuit?
Also do you know anything about electric windows? my right one started making a kinda crackiling noise the other day and now it stops about 25/30ml from the top and won't close fully,it's very slow and squeaky going up and down now aswell
PostPosted: Sun Feb 23, 2014 3:08 pm Up
You are welcome,sorry for the late reply,well as you connect that button to the circuit,everything will be back to normal :).
About your window regulator,you need a replacement,try scrapy yard for a second hand one.
PostPosted: Sun Feb 23, 2014 4:25 pm Up
Can confirm - I had to re-solder mine the other week, only took two minutes and worked fine.
