Online Now [398]:
Visitors: 398
Today: 29524
Total: 142412355
Forums › The Car › 206 Problems › Rust hole in bulkhead
PostPosted: Wed Feb 19, 2014 11:23 am Up
Anyone else experienced a rust hole in the bulkhead below the pollen filter.
Time to get the grinder and welder out before the MOT in April I think.
PostPosted: Wed Feb 19, 2014 1:38 pm Up
I had that, you need to remove the dash and sound proofing to do it properly/not set the car on fire
PostPosted: Wed Feb 19, 2014 3:03 pm Up
Seen it on the other side of a 206. That seam does seem to be a problem though.
PostPosted: Wed Feb 19, 2014 4:12 pm Up
Mine was both believe or not! It was incredibly bad on the passenger side, about 10 to 15cm strip had to be welded in
Andrew
PostPosted: Wed Feb 19, 2014 4:51 pm Up
Ouch, I just checked mine after seeing this. Drivers appears fine but the passenger side below and behind the strut there is an orange tinge going on where the two panels are moulded together. Only appears to be surface though
Why does this happen and how can it be prevented, if anything?
My 206 thread
www.detailedbyandrew.com
tom2581
PostPosted: Wed Feb 19, 2014 5:18 pm Up
mines started to rust i'll treat at weekend if i can get chance
PostPosted: Wed Feb 19, 2014 5:53 pm Up
Water gets in through the vent I suppose.
PostPosted: Thu Feb 20, 2014 1:58 am Up
To who evers have not rusted, I advise using some stone chip, and also remove your rear section of your front wheel arch guards, it rots out on the ledge just below the engine bay
Andrew
PostPosted: Thu Feb 20, 2014 2:58 pm Up
Sorry for the bad picture as it is night time
There's a bit of a surface thing going on I'm not sure of it's surface stuff or some kind of sealant they mght have used. My engine bay is not colour painted like Ryton made 206s
Doesn't look like there would be rust through to the other side of the metal. I'll get some stone chip though
My 206 thread
PostPosted: Thu Feb 20, 2014 3:10 pm Up
Why where was yours made? How old is it?
Andrew
PostPosted: Thu Feb 20, 2014 8:41 pm Up
Poissy, France and it is 6 years old
My 206 thread
