Latest: Kifi69
Overall: 17183
Online Now [548]:
Visitors: 547
Today: 35846
Total: 144182906
Forums › The Car › 206 Problems › Top Mount Help
Top Mount Help
rlees85
PostPosted: Thu Feb 20, 2014 4:41 am Up
Yes I have searched, through the hundreds of top mount topics but nothing really answers what I am looking for Wink
1 - Do you need any special tools to replace the bearing in the upper spring seat? I brought a kit that includes the bearing and top mount rubber, but no idea how the bearing is installed (or old one removed) just by looking at it.
2 - Is there a way to take the suspension strut off without separating the wheel hub from the lower ball joint? Last time I had to separate this it took nearly 3 hours with the limited tools and stuff we have lying around...
Thanks ! Smile
PostPosted: Thu Feb 20, 2014 5:37 am Up
U can get the strut off without undoing lower ball joint but it can be a ball ache I personally undo ball joint, Once the spring is compressed and shock is out of car an allen or torx key and iirc 19mm (not 100% on size lol) swan neck spanner will do the trick, pently of wd40 on the nut 1st they can be bugger, I usually try get it loosend/moving while car is still on ground, helped me loads that way after removing countless 206's ssuspension lol
southwestchap
PostPosted: Thu Feb 20, 2014 6:38 am Up
21mm, just swapped springs on Monday Very Happy
Conners300983
PostPosted: Thu Feb 20, 2014 2:21 pm Up
I got the strut out without popping the ball joint. I cut a set of cheapo eBay spring compressors down to fit up in the strut tower and compressed the springs in situ.
Conners300983
PostPosted: Thu Feb 20, 2014 2:24 pm Up
And just to add to that, no special tools are needed for the bearing, it's pretty self explanatory once it's in front of you. Just have a look at the orientation of the old components s you take everything apart. And an impact wrench with a deep socket works wonders on the top nut if you can get hold of one.
