Latest: Andyblue64
Overall: 17123
Online Now [131]:
Visitors: 130
Today: 59653
Total: 98814621
Forums › The Car › 206 Problems › gti180 cat
gti180 cat
gogs_macaulay
PostPosted: Sun Mar 02, 2014 9:10 am Up
any tips on how to fit a cat to a gti180. looks like the manifold clamps gonna be hard to get too.
PostPosted: Sun Mar 02, 2014 1:00 pm Up
I recommend that they be done by prof. as it's not an easy to job to be done by yourself.
PostPosted: Sun Mar 02, 2014 1:01 pm Up
Clamp is easily accessible from underneath.
PostPosted: Sun Mar 02, 2014 2:38 pm Up
I found it tight to get to but as mentioned from under the car is easiest way to get to the clamp. I had mine on axle stands.
DanT
PostPosted: Sun Mar 02, 2014 3:24 pm Up
The clamp definitely wasnt easy to get to on mine, from underneath or above! There is really not a lot of room and if the clamp is in the same position as mine was you'll be there for a while haha. But just stick with it.
