Online Now [186]:
Visitors: 185
Today: 12276
Total: 143138784
Forums › The Car › 206 Problems › drive shaft seals
drive shaft seals
markysparky71
PostPosted: Wed Mar 12, 2014 3:45 pm Up
messy problem .... changed wishbones recently and must have disturbed driveshaft oil seals as today after parking up could smell gearbox oil sure enough leaking on to exhaust.
bought new oil jacked up car and could see oil seal was right out of gearbox housing..
managed to push it back in square checked it looked and felt good. topped oil up drove car around the front of the house.. feeling pleased with myself when i looked under the car at the growing puddle of new gearbox oil peeing out of the shaft seal AAARRGH!! bumped the car uo on the kerb and managed to push the seal back in again?? why has it started to pop out ?? is the seal knackered?? shafts only 9 months old or so ??
markysparky71
PostPosted: Wed Mar 12, 2014 4:06 pm Up
Seal needs changing
tsotd
PostPosted: Thu Mar 13, 2014 4:22 am Up
once you "break" the seal it will need changing, no point it keep pushing it back in as it would of been damaged and it will just keep coming out
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
PostPosted: Thu Mar 13, 2014 12:46 pm Up
Yep, common error for the inexperienced when changing wishbones. Once the wishbone is no longer locating the hub then the hub can move far enough to let the drive shaft pop out of the gearbox.
Most people just force the driveshaft back in by pushing on the hub (the oil flowing out of the gearbox makes them panic) when they should be far more careful than that.
markysparky71
PostPosted: Thu Mar 13, 2014 2:07 pm Up
cheers guys. New seal it is then, oh well thats me weekend planned
markysparky71
PostPosted: Fri Mar 14, 2014 1:58 am Up
Also dont forget the gearbox should be drained at the bung, and refilled with 1.75 litres of 75/80W
