Latest: Willy.Sea
Overall: 17168
Online Now [130]:
Visitors: 129
Today: 28630
Total: 128530926
Forums › The Car › 206 Talk › Brake pipes.
Brake pipes.
Anthonys206
PostPosted: Tue Mar 18, 2014 9:10 am Up
I have a 206 1.4 that needs a new brake pipe from the master cylinder to the drivers side wheel. Do the peugeot dealers still sell them off the shelf or do I have to go through the hassle of having them bent. Thanks.
PostPosted: Tue Mar 18, 2014 12:23 pm Up
Need the VIN number to see if it's actually still available to order as there's far to many varations.
A quick random check shows a lot of the solid pipes are no longer available Laughing
206gt160
PostPosted: Tue Mar 18, 2014 1:39 pm Up
If you remove the metal pipe line you can have them made up at a local shop for very cheap.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Anthonys206
PostPosted: Tue Mar 18, 2014 4:20 pm Up
Looks like I've found one that I'm picking up tomorrow. Thanks guys.
