Latest: Andyblue64
Overall: 17123
Online Now [442]:
Visitors: 441
Today: 89518
Total: 98600834
Forums › The Car › 206 Talk › 206 gti engine compression information, how to calculate
heyziq
PostPosted: Tue Mar 25, 2014 4:35 am Up
Hello anyone can share this few information, i knew 206 gti have 10.8.1 compression, but how exactly they calculate it.
I bet this will also help anyone trying to play around with the compression.. eg; turbo /supercharge
www.rbracing-rsr.com/c...ccalc.html
To accurately calculate compression ratio, you must know several things:
1) The bore of the cylinder (85mm)
2) The stroke of the cylinder (88)
3) The volume of the combustion chamber
4) The compression height of the piston (Ask for this from the piston manufacturer)
5) The dome/dish volume of the piston (Ask for this from the piston manufacturer)
6) The piston-to-deck clearance (See this article on piston-to-deck clearance.)
7) The thickness of the headgasket
Cool The bore of the headgasket
heyziq.com
