Posted: Thu Mar 20, 2014 4:13 pm |
hi guys, I have water coming in from what looks.like under.the.door but im not sure exactly why.
Can someone help with this
cheers
Posted: Thu Mar 20, 2014 4:16 pm |
Have a look at the black seal that runs along the carpet - is it split at all?
Posted: Thu Mar 20, 2014 4:25 pm |
Water is collecting on the seal where the mould.for the.cup holders are in the door card, so if I open the door where the cup holder is is water if that makes sence
Posted: Thu Mar 20, 2014 4:27 pm |
Okay - open the door and have a look at the black rubber seal that runs around the hole which the door fits in to.
It's likely part of it has split and is letting rainwater in
Posted: Thu Mar 20, 2014 4:31 pm |
Ok will have a look tomorrow, will also post picture.
thanks
Posted: Fri Mar 21, 2014 2:50 am |
make sure the drain holes is not blocked with dirt.
Posted: Fri Mar 21, 2014 2:56 am |
Mine does that...on the rare occasions it gets wet. I just leave some kitchen roll stuff in the gap under the door pocket!
Posted: Fri Mar 21, 2014 3:10 am |
Mine does it too...although it never seems to be much at all so im wondering if it kind of runs onto the carpet as i open the door?
Posted: Fri Mar 21, 2014 12:35 pm |
Timon2210 wrote: |
make sure the drain holes is not blocked with dirt. |
they are not block , water collects under the carmat if i dont keep on top of it
Posted: Fri Mar 21, 2014 12:41 pm |
had this issue, found out someone had taken the door card out and had ripped the weather proofing sheet inside the door, this may be causing it
Posted: Fri Mar 21, 2014 1:04 pm |
do you mean the white sheet thats stuck on inside the doorcard?
Posted: Fri Mar 21, 2014 1:40 pm |
Geforce wrote: |
do you mean the white sheet thats stuck on inside the doorcard? |
Yes.
