My dad purchased a Pug 206 1.1 lx today which has a bit of an oil leak. We believe it's coming from the Rocker Cover Gasket as it looks oily there & is dripping onto the oil filter. I just wanted some advice to see if that could well be the case
Any help would be greatly appreciated
Posted: Sun Mar 23, 2014 3:30 pm
Common problem, a new rocker cover gasket is cheap & normally fixes it.
DON'T over tighten the rocker cover bolts as you will warp the rocker cover & it will leak even more
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
