Posted: Mon Mar 24, 2014 7:55 am |
Hi all,
Relatively new to Peugeot's, got one back in December. Does anyone know where I can get standard suspension for a decent price? I'm currently on Vmax coilovers (I think), and was looking to go back to standard - especially when I go to sell the car.
I would consider a swap too, although I can't post in the exchange section.
Thanks in advance!
Scott
Posted: Mon Mar 24, 2014 1:20 pm |
Im putting some coilivers on so if you want the standard suspension I take off im sure we could come to some sort of deal.
| 1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170 | |
Posted: Mon Mar 24, 2014 1:30 pm |
if you near Nottingham I can help
Posted: Mon Mar 24, 2014 2:09 pm |
What model is it?
Posted: Tue Mar 25, 2014 3:29 am |
Thanks for the replies guys. It's a 01' 1.6 16v. Not so sure of the actual modeldue to being new to the Pug seen, although it has got an "SP" on the front grill? I'm based in south-London
Posted: Tue Mar 25, 2014 4:48 am |
Just thrown a whole set away! Shame would have been better seeing them gone to use
Posted: Tue Mar 25, 2014 5:40 am |
Ah no way! does anyone know how much Vmax coilies second hand will go for? Hopefully they'll pay for my standard ones!
Posted: Fri Apr 04, 2014 12:02 pm |
if yours is a 206 then i have a 206 gti with standard set up so ill be up for it if they will fit
Posted: Sat Apr 05, 2014 8:33 am |
I just switched mine out to coilovers and have my set sitting around waiting to be binned. They come off of a 03 1.4 8v so if they will fit yours you can have them. If you're still wanting them then PM me
