Latest: Andyblue64
Overall: 17123
Online Now [184]:
Visitors: 183
Today: 59823
Total: 98982067
Forums › The Car › 206 Talk › removing the lower airbox on the 180
PostPosted: Wed Mar 19, 2014 12:31 pm Up
is is possible to remove the lower box? when to remove mine today but wasn't sure if i should remove all the tiny pipes etc? i know on other 206s i have but they never had any pipes etc.
also there is a big pipe running to them looks like a oil breather or something... what is it?
Ben Very Happy
Uz
PostPosted: Wed Mar 19, 2014 12:38 pm Up
It's a nightmare to remove the lower box on the 180 but it's actually clip into the plate under the headlight... if you take the light out your see a clip pushed up near the end of the headlight surround. press that clip together and your box will fall down.
PostPosted: Wed Mar 19, 2014 12:40 pm Up
yer i got that far, i found that clip and got it loose as had bumper off for other things today, i was just wondering what to do with the pipes etc, they ok to just unplug etc?
i have clipped it back for now,
Uz
PostPosted: Wed Mar 19, 2014 12:43 pm Up
Have a look at my 180s album on my facebook it shows what i did with mine but everything came off from the original intake system and a few mods to a couple of the parts and put them back as certain bits are still needed.
mattymj
PostPosted: Wed Mar 19, 2014 1:14 pm Up
Will need to remove the passenger wheel and arch lining to get to it easier. Dont disconnect the electric plug going to a solenoid where them small pipes go. With affect the ecu
PostPosted: Wed Mar 19, 2014 1:42 pm Up
Kwl will have a butchers Smile
Yer had the arch liner out today as well lol. Thats twice this week I had it out now haha.
DanT
PostPosted: Wed Mar 19, 2014 2:46 pm Up
Thats everything i removed lol.
stuy180
PostPosted: Wed Mar 19, 2014 6:05 pm Up
I do my very best to get mine out at least twice a week Cool
PostPosted: Fri Mar 28, 2014 2:03 pm Up
Did you fit a catch tank or anything to the breather pipes afterwards?
DanT
PostPosted: Fri Mar 28, 2014 2:13 pm Up
Two little filters that go on the fresh air pump hoses and some blanking pins for the vacumn pipes came with the Simota kit i bought dude. However it still looked a bit untidy in my eyes so i got some new vacumn hose and some rubber hose to fit to the pump from work and shortened it etc to tidy things up a bit Smile
