Latest: S2cgm
Overall: 17178
Online Now [80]:
Visitors: 80
Today: 19689
Total: 136875896
Forums › The Car › 206 Problems › Electric Windows & Indicators not working
BenniBoi90
PostPosted: Sat Mar 29, 2014 3:55 am Up
Surprise surprise my dad has another issue with his 206. He was trying to sort out his radio, the wally that previously owned it was a butcher & cut some leads & now the radio won't stay stored, & now the electric windows & the indicators don't work & when you put the wipers on they go on & on for ages.
We called out the AA & he checked all the fuses & said they're fine but he thinks it may be a relay & that should have a diagnostic test done. Before getting a test done I thought I'd ask on here if some has had this issue before & knows what the problem might be saving me the cost of a diagnostic test. Or would it just be better to pay for the test?
LiamMiller
PostPosted: Sat Mar 29, 2014 6:31 am Up
The radio storing problem is a regular occurrence swapping the red and yellow wires solved the problem for me and a few others. As for the indicator and window situation it sounds like it could be a relay.
BenniBoi90
PostPosted: Sat Mar 29, 2014 8:18 am Up
Yeh my dad had a look & both relays in the fuse box in the engine bay looked burnt. I've brought 1 relay from the main dealer & the other will be in on Wednesday. As for the radio he was told that & that's what he was trying to do when the indicator thing happened & the clown that owned the car previously has cut the yellow wire a but too much as he said its a bit short lol
PostPosted: Sun Mar 30, 2014 7:23 am Up
Think! Don't assume the "clown" cut the yellow wire. There may be a bigger wiring problem and the yellow wire might have been cut because of a short somewhere else.
It wouldn't be the first time wiring was put back to standard to find it had been botched for a reason.
It might not have been the perfect repair but it might have been done to avoid damaging something else. Go ahead with you plan but be careful and do lots of checking.
BenniBoi90
PostPosted: Sun Mar 30, 2014 3:10 pm Up
It's alright I misunderstood my dad, it was the yellow wire on his radio that was too short not in the car. I think he's probably just gonna put another radio in & then swap the wires around if need be
BenniBoi90
PostPosted: Thu Apr 03, 2014 8:31 am Up
Got the second relay yesterday but that still hasn't solved the problem. Have to admit it's really baffled me as I haven't got a clue what else it could be
