Latest: heikkisj
Overall: 17126
Online Now [37]:
Visitors: 36
Today: 4077
Total: 100337117
Forums › The Car › 206 Talk › Front subframe differences - GTI 180 Rod Conversion
AWK-53
PostPosted: Fri Mar 21, 2014 4:31 pm Up
I've a GTI 180 that I'm building for racing and want to ditch the cable gear change and swap to the rod setup. I know I need to change the subframe but which one's can be used? I don't think they are all the same so which one do I need or do I just get a 138 GTI one?
There's 3 206's in the local scrappy but none GTI's so thought I'd ask before going to a proper breakers and getting a 138 subframe.
Any help appreciated
PostPosted: Sat Mar 22, 2014 4:14 am Up
You cant just use the rods because it will hit the exhaust manifold. That's why the 180 used the cable set up in the first place.
The only difference I know if with the 180 subframe is the mounts or the exhaust are welding to it.
macj
PostPosted: Sat Mar 22, 2014 4:25 am Up
Does the 180 have the tower welded on to take the gearchange rod ball linkage Question
simpsonrc
PostPosted: Sat Mar 22, 2014 3:15 pm Up
the gti 180 subframe has the mount for the rod change gear selector.
AWK-53
PostPosted: Sat Mar 22, 2014 3:21 pm Up
Thanks for the replies, I'm gona be using a different manifold to the 180 one so hopefully that shouldn't be a problem.
I'll see if I can put a pic up - where would the tower be?
AWK-53
PostPosted: Sat Mar 22, 2014 3:27 pm Up
Quick pic of my 180 subframe, is that the tower just in front of the steering rack?
PostPosted: Sat Mar 22, 2014 3:40 pm Up
Looks identical to the 138 subframe.
simpsonrc
[img]
[/img]
yes thats the one
AWK-53
PostPosted: Sun Mar 23, 2014 5:08 pm Up
Cheers Simpsonrc that's great Very Happy
Schumi
PostPosted: Mon Mar 31, 2014 4:23 pm Up
You dont need to change subframe on GTI 180 for gear rods. Just change your exhaust manifold for clearance.
2005 206 RC RED
