Online Now [548]:
Visitors: 547
Today: 217046
Total: 152842186
Forums › The Car › 206 Problems › Every time my car has problems it comes in 3s!
frenchfrog40
PostPosted: Sat Apr 05, 2014 5:15 pm Up
Its been a while since it had problems but again, it has come in 3s:
1) Comms unit has now given up, when you indicate left, it will indicate for a few "ticks" and then turn the lights on and give up on indicating.
2) Something clonks and scrapes when on almost full left lock, i think its the longer bolt we put in the strut brace because we lost the other one
3) This is the one i need help with!!! Once a day for the past 3 days my car has started flashing "STOP" at me, the ABS light comes on, the centre display says "breaking fault", the speedo decides im not going anywhere and it starts beeping at me. When i stop and put the handbrake on it feels the need to tell me iv done this with more beeps and a nice message on the display.
I turn the car off and on again and its fine...
Any ideas?
4) (Yes its given me one for luck this time) since i put the strut brace on the car has started to overheat, its fine if your moving but when you stop, the temperature creeps up, even with the fan on.
Any idea?
Chris
Iv had:
PostPosted: Sat Apr 05, 2014 5:43 pm Up
Dodgy earth or alternator?
frenchfrog40
PostPosted: Sun Apr 06, 2014 5:01 am Up
Everything seems to be charging fine etc. ill have a look anyway, thanks.
Iv had:
PostPosted: Mon Apr 07, 2014 8:08 am Up
3 is possibly broken or damaged ABS ring or dislodged wire.
