Latest: Mr-Koekwaus
Overall: 17125
Online Now [80]:
Visitors: 79
Today: 21807
Total: 99353798
Forums › The Car › 206 Problems › Bit of a tricky one.. Seat removal
welsh.Z.S.
PostPosted: Wed Apr 02, 2014 3:52 pm Up
Right guys as mentioned in my other thread, my passenger front won't slide backwards sometimes, now I'm wanting to take the seat out to have a good look etc, I can get to the rear 2 torx bolts, but the front ones are under the where the seat is and the seat wont move, anyone got any ideas?
206gt160
PostPosted: Wed Apr 02, 2014 4:30 pm Up
Grind the heads off with a Dremel
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
welsh.Z.S.
PostPosted: Wed Apr 02, 2014 4:37 pm Up
I cant get to the bolts as the seat wont move lol
206gt160
PostPosted: Wed Apr 02, 2014 4:45 pm Up
Can you touch the bolt at all with your finger?
welsh.Z.S.
PostPosted: Wed Apr 02, 2014 4:48 pm Up
I cant bud, the seat is stuck all the way forward so is literally sitting on top of the bolt Sad
206gt160
PostPosted: Wed Apr 02, 2014 5:00 pm Up
Right have you tried a load of dw40 and then sitting in the seat and forcing it back with your body, I used my whole body weight to slam back and mine freed up, was he only thing that did work
sean.r.steward
PostPosted: Wed Apr 02, 2014 6:01 pm Up
See if you can slide a long screwdriver down the runners. Might be a coin jamming it or somthing like that
welsh.Z.S.
PostPosted: Thu Apr 03, 2014 4:07 am Up
Anyone ever had this?
welsh.Z.S.
PostPosted: Thu Apr 03, 2014 4:08 am Up
Have tried dude, doesn't seem to be anything there, the seat moves maybe a cm or 2 but no more
206gt160
PostPosted: Thu Apr 03, 2014 5:23 am Up
Check that when the seat adjuster is pulled that it disengages from the seat runners, you will know what I mean when you look. Will probably need to get a torch under to look
Lecktorious
PostPosted: Thu Apr 03, 2014 6:19 am Up
Trade Rating: +59
Try refitting the bolts you have taken out and sliding the seats back. The seat might jam if the runners aren't sitting correctly.
'98 Nile Blue 306 GTi 6
welsh.Z.S.
PostPosted: Sat Apr 05, 2014 2:33 am Up
I still Can't get it to move Sad
PostPosted: Sat Apr 05, 2014 5:00 am Up
Get hold of a spare seat and then attack the existing seat with hack saw or angle grinder!
sean.r.steward
PostPosted: Sat Apr 05, 2014 2:19 pm Up
yer agreeing with you there that would be the next step
