Posted: Sun Apr 06, 2014 8:20 am |
hi all, i have read that the BSI can corrupt if the proper battery reconnection procedure is not folowed correctly. if it has been corrupted in this way will disconnecting and re connecting the battery in the specified sequence uncorrupt the BSI? the reason i am asking is that the 206 in question flashes its headlights every minuite or so and has a "bleep" coming from the dash or steering column shroud. i wondered if this was due to battery or another fault, any theories? its a 52 plate 1.1 look so multiplexed and does not have automatic head lights
Posted: Sun Apr 06, 2014 8:24 am |
You could try a BSI reset, although the headlight and beep could be related to the com2000 unit being faulty.
Posted: Sun Apr 06, 2014 12:26 pm |
They love a BSI reset here
Posted: Wed Apr 09, 2014 4:17 pm |
will give the bsi a reset and see what happens.
Posted: Thu Apr 10, 2014 7:01 am |
Have done a few bsi resets in my time with my beloved peugeot, and can say has sorted a few problems out, a new one on me cropped up the other day.
My rear wipers are programmed in the bsi to come on when reversing, and stopped working a couple of weeks back, (still worked with the wiper switch but not when reversing) did a bsi reset no joy.
Was cleaning out the inside of my car the other day, a good half hour which in turn activated the economy mode, radio on, doors open etc, i started her up and proceeded to reverse up the drive, and presto the wipers were working again. how weird new one on me.
| 206 2ltr Hdi glx 53 plate | |
Posted: Thu Apr 10, 2014 11:56 am |
My rear wiper only works when it fancys (fine with normal switch)
Posted: Thu Apr 10, 2014 12:15 pm |
DREWDEN wrote: |
You might find the reverse light switch has an intermittent fault
Mine was like this for a while till I cleaned the switch, I noticed it was intermittently working as my 206 has parking sensors on & sometimes they wouldn't activate.
Posted: Fri Apr 11, 2014 6:46 am |
MrBSI wrote: |
DREWDEN wrote: |
Mine was like this for a while till I cleaned the switch, I noticed it was intermittently working as my 206 has parking sensors on & sometimes they wouldn't activate. |
Thanks for info will investigate if problem happens again
Posted: Fri Apr 11, 2014 9:38 am |
wher do i find the bsi unit? i looked in the haynes manual and it says it is under the fusebox but it doesnt seem to be there. the pictures are also different to my fusebox.is it integrated with the fusebox or is it completely seperate? are they in different places on different models. mine is a 52 plate 1.1 look.
Posted: Thu May 01, 2014 11:53 am |
does a new bsi have to be programmed to the car or is it plug and play?
Posted: Thu May 01, 2014 11:56 am |
gibbo300 wrote: |
hi all, i have read that the BSI can corrupt if the proper battery reconnection procedure is not folowed correctly. if it has been corrupted in this way will disconnecting and re connecting the battery in the specified sequence uncorrupt the BSI? the reason i am asking is that the 206 in question flashes its headlights every minuite or so and has a "bleep" coming from the dash or steering column shroud. i wondered if this was due to battery or another fault, any theories? its a 52 plate 1.1 look so multiplexed and does not have automatic head lights |
forgotbto say the front window wiper come on as well
