Latest: williamekstrom
Overall: 17124
Online Now [102]:
Visitors: 101
Today: 13934
Total: 99345942
Forums › The Car › 206 Problems › Gti 180 gear selection
mattymj
PostPosted: Mon Apr 07, 2014 12:32 pm Up
Hi all.
The gears on my 180 are sometimes hard to select. Is there a certain way to realign it all as its not been 100% since a clutch change.
gpvecchi
PostPosted: Mon Apr 07, 2014 2:33 pm Up
I had this problem, is the feel like the gear stick excursion is not enough to select the gear? In particular, 2nd and 4th gear? I changed for the second time the selection plate that is outside the gearbox (70€). There's a ridicoulus anti friction tiny thing that breaks easily, leaving too much movement to the plate. Now I'm looking for some modification.
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
mattymj
PostPosted: Mon Apr 07, 2014 3:03 pm Up
Well I just removed a nut below it a circle. Lift this up you will be able to pull the selector off. Leaving a shaft with two little shims. I put a little copper grease on the shaft. Carefully refitted everything. Now the gear selection seems smoother!
