Latest: lio94
Overall: 17181
Online Now [285]:
Visitors: 284
Today: 8678
Total: 141763586
Forums › Tuning, Modification & Legal › Project Cars › Kirks 1.4Hdi work horse :)
kirk46
PostPosted: Wed Apr 09, 2014 12:44 pm Up
Hi all new to the forum
Got a bog standard 1.4Hdi
Here is some pictures of what ive done so far Smile
70 horses of pure derv lol Razz
De Badged the rear
Gave her a service
No idea why i've only got this one shot, but after the air and pollen filter it gets oily Smile did the gearbox oil too.
Wanting to get a K&N panel filter when funds allow
Horrid black B pillars
No idea what they used to make them black/blacker but it felt horrible and greasy :/
That's better Smile
That's not a scratch it the refection of my white zip lol
Next was knocking the insides out of the cat Smile
Those clamps where a real PITA to get off...
I had to put a bolt through with 2 nut inbetween and screw them out to open them up.
Noticed turbo now comes in at 1800rpm instead of 2000rpm Smile
The brake servo is leaking air, the gaiter has come off had a go at putting it back on with no joy atm.
Got some Ph2 rear lights on there way and mist jet washers Smile
Few more things i want to do/get:
Alloys
Remap
Colour coded door handles
Front and rear sports bumpers
straight through back box
gazza82
PostPosted: Wed Apr 09, 2014 1:39 pm Up
Back box might be a waste ... diesel exhausts work differently to petrol ... it will look better though granted!
Get crystal lights for fronts too ... the single H4 bulbs are cr@p ...
southwestchap
PostPosted: Thu Apr 10, 2014 10:57 am Up
Nice to see another 1.4HDi, looks pretty tidy and a real early one at that. Couple of good plans there. definitely replace the standard rear exhaust box. you'll get a nice DI Growl then Very Happy .
I keep meaning to remap mine but always find something extra to do so just doing it all before I get it mapped.
kirk46
PostPosted: Thu Apr 10, 2014 12:19 pm Up
cheers guys.... Smile
washers came today Smile
still waiting on the rear lights.
and yes i forgot about the headlights Smile
PostPosted: Thu Apr 10, 2014 12:46 pm Up
Get rid of the standard air box, get a cone on it with a direct cold air feed, make sure its a big cone though!
Also fit a decent front mount then get her mapped, and I expect you will be presently suprised!
kirk46
PostPosted: Thu Apr 10, 2014 2:47 pm Up
dont have the cash for a FMIC yet.... but i would like too Wink
i thought just a k&N panel filter will be fine on a diesel?
also are crystal lights a straight swap?
thanks
kirk46
PostPosted: Fri Apr 11, 2014 12:30 am Up
sorry double post...
would a intercooler from a 1.4Hdi C3 be ok?
thanks
Antknee
PostPosted: Fri Apr 11, 2014 12:45 pm Up
thanks
Think the power steering pipes that run across get in the way, i looked into taking the 1.6hdi cooler and putting it on mine but it was too much hassle in the end, ended up buying a small used fmic but again, couldnt really be bothered, so im buying a gti instead lol
kirk46
PostPosted: Sat Apr 12, 2014 9:03 am Up
hmmmmm thought it would be an easy fit Sad
just been looking at a friends 207 1.6Hdi and it isnt much different at all...
Antknee
PostPosted: Sat Apr 12, 2014 4:37 pm Up
The 206 1.6 hdi is the same engine as the 207 (i think) its also a modified version of the 1.4 you have, just with slightly bigger cylinders and a couple of other bits including the intercooler
kirk46
PostPosted: Wed Apr 16, 2014 10:44 am Up
few updates:
got these:
and there fitted along with a straight through back box
mist washers
replaced the droplinks.
need to order wishbones as mine are fubard :/
also found a leak from a seal heres the pic
that rubber seal if thats what it is was a few mm away from the transfer box or whatever its called and it leaking gear oil Surprised
kirk46
PostPosted: Thu Apr 24, 2014 4:17 pm Up
another update:
replaced the ARB droplinks and bushes.
the bushes were fubard:
GTI fuel cap
colour coded boot strip Smile
before
after
Also should be getting that drive shaft oil seal done next week.
and got a race chip pro on its way Smile
sicskate
PostPosted: Sun Apr 27, 2014 5:32 am Up
Trade Rating: +13
A remap was the first mod I did on my 1.4hdi, by far the best £200 I've spent on any car!
307 1.4hdi Smile
