Latest: lio94
Overall: 17181
Online Now [224]:
Visitors: 223
Today: 25212
Total: 140969800
Forums › The Car › 206 Problems › Indicator light not staying on
bruceykins
PostPosted: Thu Apr 17, 2014 1:00 pm Up
Okay so I've had this problem for a bout 4 months. When I push the stalk up (to go Right) or down (To go left) the stalk stays there and the indicator light on the dashboard flashes but sometimes the light on the dashboard and the clicking noise stops. So for instance the stalk stays up but the indicator is not making any noise and the light on the dashboard to say I'm indicating is not flashing. Which in turn makes the indicator on the outside stop working.
I took it to my mates garage and was quoted £300!!!!! to get it fixed.
Has anyone had this problem and what do you recommend I do.
Edit* I was actually quoted £150- £300 including labour
PostPosted: Thu Apr 17, 2014 1:08 pm Up
You need to tell us the year of 206 for a start.
2 completely different electrical systems have been used on the 206 & the known faults that affect the indicators are different depending on the electrical system fitted to your car.
PostPosted: Thu Apr 17, 2014 1:12 pm Up
Either the stalk (pre-plexed) or com unit (multi-plexed) is shot. Do your headlights flash on when the indicator stops?
£300 for a new com is expensive as they are only £150 (ECP Valeo part) and take about 20 minutes to fit even for a DIYer. They could have got the price from Peugeot though.
£300 for a new single stalk is highly over priced.
PostPosted: Thu Apr 17, 2014 1:14 pm Up
If its non plexed it could also be the relays soldered on to the BSI unit Wink
PostPosted: Thu Apr 17, 2014 2:47 pm Up
If it is pre-plex it could just be the stalk which, if you are a competent DIYer, is a relatively easy fix at £0
bruceykins
PostPosted: Thu Apr 17, 2014 2:55 pm Up
My car is an 52 plate car
That's what my work friend said aswell. I'm driving to Nottingham very soon so I really need to get this fixed before then. But I'd rather not pay all that money only to sell it on in a few months time.
bruceykins
PostPosted: Thu Apr 17, 2014 3:04 pm Up
No but my lights always come on and stay on when I'm driving. I've also been through two batteries within the last year.
Well he said anywhere from £150-£300.
PostPosted: Thu Apr 17, 2014 3:23 pm Up
Has your car got auto headlamps fitted?
Light & rain sensor behind rear view mirror.
Either:
Someone's turned Daytime running lamps ON in the BSI setup configuration ( unlikely )
Light sensor ( if fitted ) is faulty.
You have a CAN communication issue.
