Forums › The Car › 206 Problems › 206 GTI Oil Pressure Switch Location? |
Posted: Thu Apr 17, 2014 11:06 am |
Hey there guys. I bought an 02 206 GTI 2.0 back in August and now I'm getting the "low oil pressure" warning and stop light. I've had the pressure tested and it's fine I just need to change the switch (Which from I've heard is easy) Can anyone tell me where it is?
Posted: Thu Apr 17, 2014 2:16 pm |
Right on the front of the engine above the oil filter.
