Latest: Mr-Koekwaus
Overall: 17125
Online Now [45]:
Visitors: 44
Today: 30725
Total: 99415894
Forums › The Car › 206 Problems › GTI180, running strange below 2000rpm
Neepamonsteri
PostPosted: Thu Jul 30, 2015 8:11 am Up
Hey!
Car works perfectly above 2000rpm! But below that there is no power/torque at all. It responds to throttle very badly and kinda missfires or doesnt fire at all on those rpms. Its giving me hard time to start moving again from crossroad. I have to pump the throttle to get like 2,5k rpms .. otherwise it tugs like hell or the engine shuts down.
Lately I've changed the following:
-MAP sensor
-Coolant temp sensor
-spark plugs
-all filters
Have you guys any idea what could cause this? I haven't changed coil pack yet because I'm not sure if it'd help and coil pack is pretty expensive here at my local dealer. Could it be worth replacing?
the car is GTI180, 2005, 100tkm
Thanks!
Vexs
PostPosted: Thu Jul 30, 2015 8:16 am Up
Wasn't there a software update rolled out to address this flat spot around the 2k mark on some of the 180's?
My GTI 180
My Old 1.4 8v
Neepamonsteri
PostPosted: Thu Jul 30, 2015 8:24 am Up
Thanks for reply Vexs! Can anyone confirm this? Is there a way to check which software version I have? And when did that update roll out?
/m
mattymj
PostPosted: Thu Jul 30, 2015 11:07 am Up
Could be all manner of things. Where are you situated. Maybe check the pp2000 map to see if anyone can read the ecu.
What spark plugs did you use?
PostPosted: Fri Jul 31, 2015 2:10 am Up
well have u considered a faulty throttle body,as you know it's a motorized throttle body,so with 100K on clock,maybe it's worn out,you can try having it cleaned,then to reset auto adaptive ,and see how things goes,you need PP2000 to do this.
PostPosted: Fri Jul 31, 2015 3:30 am Up
Sounds like coil pack to me if the spark plugs have already been changed. What plugs are in there?
Neepamonsteri
PostPosted: Tue Aug 18, 2015 1:48 am Up
Hey! I live in Finland so I think the pp2000 map is no use in this situation.. Crying or Very sad
I got new set of plugs from local dealer which were listed for GTI180. Don't remember the exact model number tho (NGK's anyway, but I'll check and get back to you guys)
Neepamonsteri
PostPosted: Tue Aug 18, 2015 2:14 am Up
Is there a certain way to diagnose faulty coil pack?
Btw, I've been getting "anti pollution fault" twice now. The running problem is "on" all the time but I got this error twice and both times it did disappear in the next start or the second one. I got to read ecu faulty codes with my OBD2 reader the second time "anti pollution fault" appeared. The reader finds error code P1621. I tried with two different softwares and here are the results:
i.imgur.com/bSGv0WQ.png?1
i.imgur.com/dr0FEPH.png?1
How would you interpret those?
and for the record when the antipollution fault is not shown, there are no fault codes found in the ecu..
McGuiverNL
PostPosted: Tue Aug 18, 2015 2:56 am Up
Don't think there's a way to measure coil pack faults...?
I did notice on the old and faulty ones I've seen (also my replaced one) that the housing plastic shows cracks on closer inspection; maybe worth checking
And have you checked the earth strap to gearbox yet? Sounds like it -could- be connection (signal) loss at low revs throwing the fault which might be poor current flow or even engine tilt disturbing cable connection.
2005 LHD black RC (GTi180)
PostPosted: Tue Aug 18, 2015 3:07 am Up
That is a PSA specific code which is why you are getting different faults for different manufacturers.
Generic software sometimes is no help at all with giving an indication of a fault.
This is what comes up for P1621 on a PSA
Control module Long term memory performance / Immobiliser code words not matched
What sort condition is the battery in? Also worth checking all the connections for the battery. The ECU needs a stable battery voltage, otherwise it can throws all sorts of odd things
You have also said that you have NGKs fitted. Bin them and get Denso or Bosch. They could be sending a rogue signal spikes back to the ECU.
Neepamonsteri
PostPosted: Tue Aug 25, 2015 3:31 am Up
Battery should be in good shape. Connections to the battery are good.
And as Timon2220 asked, I tried cleaning the throttle body. No results Sad
I think this "anti pollution fault" was just random and has nothing to do with this.. Once the codes was reset, it never appeared again but the fault Im talking about is on all the time
About this earth strap to gearbox, where is it exactly? Possible to check without lifting the car?
I once heard someone talking about cold start wire, but I don't think it could affect like this?
I found a guy with PP2000 living close to me. So I had the car read and it didnt show any fault codes.
Heres some live data as pics:
s72.photobucket.com/us...t=9&page=1
Do these seem normal to you guys?
I made two notes:
- intake air temperature was pretty high (58-62 celcius)
- Cylinder coil charge time 1 differed from the 3 others. (while throttling it jumped between 1.87-1.99ms and others kept stable 1.99ms)
ps. Could faulty lambda sensor cause smthling like this? Which one of those values shows lambdas functioning?
McGuiverNL
PostPosted: Tue Aug 25, 2015 5:43 am Up
Earth strap is tucked away under the battery box and to check it properly I'd say that box needs removing; it's pretty straightforward (remove battery after sticking to disconnect procedure, three bolts in base of box and carefully remove vent pipe and cables from two holders)
The negative lead goes down to the gearbox and jumps from there to the chassis lower down on the suspension turret. The cable ends might fray or corrode right next to the crimped on eyes, and it's worth checking/cleaning the surfaces that the eyes bolt onto while you're down there Smile
yokel
PostPosted: Sat Sep 12, 2015 5:20 am Up
I had a similar issue to this lately. Changed things, cleaned things yet juddered early in morning and couldn't move until the secondary air pump cut out. Pug dealer didn't really know what was up either. I ended up buying a set of cables and software off of ebay and had a sniff about myself. I reset the adaptive system and all is running well again. I can start the car and drive straight off and not have to wait for secondary air pump to cut out. The general judders and lag in pulling away have all gone as well. Nice to have the car back again!
