Latest: Mr-Koekwaus
Overall: 17125
Online Now [477]:
Visitors: 476
Today: 21527
Total: 99526762
Forums › The Car › 206 Problems › oil in coolant resovir
Go to page Previous  1, 2
coolhas
PostPosted: Thu May 01, 2014 3:29 pm Up
Hi thanks for that I've flushed it and it seems to have gone dirty within 2. Hours looks like chocolatey colour sludgeish there's nothing wrong with engine oil bu transmisson oil low again I'm sure it's that mixing with it
PostPosted: Thu May 01, 2014 4:17 pm Up
Does the ATF and engine coolant share a common radiator?
If so is that failed?
coolhas
PostPosted: Thu May 01, 2014 4:38 pm Up
I'm not sure if they do hopefully some one else might know ?
PostPosted: Mon May 05, 2014 2:36 pm Up
Yes they do,the car with an automatic transmission,will have a hose next the lower hose (the one you drain the radiator and coolant system from),it's smaller in diameter,so yes they share same radiator.
Well the problem might be in the gearbox oil cooler,so it mix the oil with coolant,so replace that part will fix the problem,but I'm afraid that the gearbox is going to be damaged because of water getting inside it.
Page 2 of 2
