Posted: Fri Apr 25, 2014 2:49 am |
I recently ordered a replacement wing mirror for my 206 2.0 Hdi after a cyclist kindly knocked my other off.
As you can see in the picture my current one (still attached) has a white connected, the new one a brown and orange connector. I'm wondering if anyone knows if these are hot swappable if I just cut the leads and reattach in the right order?
The only reason I ask is because the seller is being a pain about returns.
| Diagbox available for use in Stroud, Gloucestershire. | |
Posted: Fri Apr 25, 2014 3:25 am |
don't know
but if you not sure don't buy
Posted: Fri Apr 25, 2014 3:30 am |
omega wrote: |
don't know
but if you not sure don't buy |
With the greatest respect this isn't exactly helpful to the situation. When ordering the part the full chassis number was given so this wasn't a mistake on my part.
Posted: Fri Apr 25, 2014 4:19 am |
jackwetson wrote: |
omega wrote: |
don't know
With the greatest respect this isn't exactly helpful to the situation. When ordering the part the full chassis number was given so this wasn't a mistake on my part. |
then in fairness if it isn't a fit and the guy told you it would ect.....he can't argue about a return
Posted: Fri Apr 25, 2014 4:26 am |
I appreciate your comments, but I do know my way around consumer law The question is to if I can make it fit, it'l be quicker for me to use a soldering iron rather than battle out the return.
Posted: Fri Apr 25, 2014 6:18 am |
You could go to Peugeot and buy the adaptor loom, and since they make an adaptor, I can't see any reason you couldn't solder your old plug onto the new mirror. Just be a case of following the wires in each mirror to make sure you connect the right ones together.
Edit. And as if by magic, here's a similar thread
Posted: Fri Apr 25, 2014 7:23 am |
macca1411 wrote: |
Edit. And as if by magic, here's a similar thread |
Perfect thank you Couldnt find this when i searched
Posted: Fri Apr 25, 2014 11:13 am |
Hi mate, yes you can chop the ends of both. However I would get the broken one and cut the end of that and and put it on the new mirror. Dead easy.
Posted: Sat Apr 26, 2014 9:25 am |
Just finished it all now, 10 minutes of soldering and it works perfectly. Thanks all!
