Posted: Thu May 01, 2014 2:35 pm |
Posted: Thu May 01, 2014 3:18 pm |
Gasket from any Peugeot / Citroen main dealer.
Posted: Thu May 01, 2014 3:20 pm |
P1160 - intake manifold
P1161 - throttle motor position
Try clearing them. See if they come back
Posted: Thu May 01, 2014 3:21 pm |
MrBSI wrote: |
Gasket from any Peugeot / Citroen main dealer. |
Not eBay????
Edward wrote: |
MrBSI wrote: |
Not eBay???? |
That's for the lazy sods who want to pay over the odd's
Posted: Fri May 02, 2014 7:01 am |
Probably end up being the tb at fault, quite common to fail
| Team Impossible Possible
