Latest: lio94
Overall: 17181
Online Now [95]:
Visitors: 94
Today: 143501
Total: 140781446
Forums › The Car › 206 Talk › so disappointed, still noisy!!!
19Connor92
PostPosted: Fri May 02, 2014 1:29 pm Up
just had the subframe out and changed the exhaust manifold and gasket, for a second hand one which i leak checked at work. put it all back together and there is still a terrible noise coming from the flexi joint had my hand all around exhaust system and no leaks.
this noise is really peeing me off, sounds like a blow but not.
any suggestions? 206 gti 180.
anyone had this problem? thinking of getting a rigid de cat pipe made?
commandosqueak
PostPosted: Fri May 02, 2014 2:24 pm Up
the manifold or head could be wrapped, check for leaks arounf the manifold again
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
19Connor92
PostPosted: Fri May 02, 2014 2:34 pm Up
cant find a leak any where. i'm sure its the flexi all heat shields and anchor nuts are out no rattles either.
commandosqueak
PostPosted: Fri May 02, 2014 3:00 pm Up
double check the flexi again
19Connor92
PostPosted: Fri May 02, 2014 3:04 pm Up
i have lol can not feel a blow, have wrapped it in heat wrap. has muffled the sound slightly.
commandosqueak
PostPosted: Fri May 02, 2014 3:12 pm Up
so there is def a leak, i would take the bit out and have a closer inspection
19Connor92
PostPosted: Fri May 02, 2014 3:24 pm Up
its all been out cant find any thing. dont wanna pay a garage thou lol.
ukskater01
PostPosted: Sat May 03, 2014 4:34 am Up
Is the cat ok?
PostPosted: Sat May 03, 2014 4:44 am Up
With the engine at idle, get a mate holding a cloth to put his hand firmly over the tailpipe while you are underneath looking for the leak. The pressure from the tailpipe being blocked will exaggerate where the leak is and make it easier to find.
Best done when engine is cold as less chance off you burning yourself and the metal hasn't expanded with heat which could cause any hole to get smaller and harder to find.
You won't do any damage this way as the pressure build up in the pipe will move your mates hand away before it gets anywhere near doing any damage.
19Connor92
PostPosted: Sat May 03, 2014 5:23 am Up
Was a new cat 1 year ago, was only a cheap one. Was thinking that could be part of the problem.
ukskater01
PostPosted: Sat May 03, 2014 6:33 am Up
I've heard a cat rattle and it had fallen apart inside. Might be worth having a look inside it
19Connor92
PostPosted: Sat May 03, 2014 1:00 pm Up
Have look inside it and no lose articles inside ?
gazza82
PostPosted: Sat May 03, 2014 2:30 pm Up
Knock it from underneath and see if anything rattles or appears to move inside .. my Alfa cat broken in two and the rear half was moving around but the front piece wasn't ...
