Latest: tc.206
Overall: 17147
Online Now [104]:
Visitors: 103
Today: 21444
Total: 116517936
Forums › The Car › 206 Problems › Catalytic converter problem
karimali831
PostPosted: Tue May 13, 2014 2:17 pm Up
Every summer I have some sort of overheating problem with the car only this time the CAT is making loud thumping sound when I rev the engine.. this was after being stuck in traffic and after a while the car felt completely sluggish with coolant temp going 90 to 100 back and forth. Nice to drive at first but when it heats up in traffic or when the weather is hot everything feels heavy and sluggish and revs being erratic at times. Every time I start the engine when it's hot the revs drops at first (as if it's going to stall!) before going to idle.
After having a look at the CAT I haven't noticed any blowing and there is no errors displaying, but something is going on inside the CAT like the baffles are damaged? And I can't be sure if it's coming from the CAT as there is no errors showing maybe it could be the middle section? Although I only recently got the full scorpion exhaust last year. Do you think the CAT is causing the overheating issue or the overheating of the engine caused damaged to the CAT? Any thoughts appreciated.
206 GTI 180
PostPosted: Tue May 13, 2014 2:46 pm Up
Well the if your CAT got a problem when the car get warmer,that means the airflow get slower,which make the performance poor,as warm air is not getting out from the exhaust as it should,which cause the engine to run bad in it's champers,this is how I think about it,I would consider a DeCat if I were you,and then car will runs much better.
karimali831
PostPosted: Tue May 13, 2014 3:00 pm Up
What's a decat, as in no cat? Won't that wave anti-pollution faults and fail MOT?
So I should be looking at one of these then?
www.ebay.co.uk/itm/BRA...2c82d08ac3
Thanks.
206 GTI 180
PostPosted: Tue May 13, 2014 3:05 pm Up
decat=No Cat as you said,it won't wave the anti-pollution fault as you will use 90 degree elbow to fit the low stream oxygen sensor,but according to the new MOT law,any car with a decat will failt MOT,so all you can do is to fit the CAT when you have mot,and decat it the rest of the year Smile
And yes,that is what you need to fit,your car will drive much better with this on,trust me ,you can remap it too Wink
karimali831
PostPosted: Tue May 13, 2014 3:37 pm Up
Car is already mapped. This pipe will replace the scorpion middle section then and directly fit onto the scorpion backbox right?
206 GTI 180
PostPosted: Tue May 13, 2014 3:50 pm Up
yes that is it,I believe Smile
karimali831
PostPosted: Tue May 13, 2014 4:38 pm Up
thanks again Smile
206 GTI 180
PostPosted: Wed May 14, 2014 1:37 pm Up
karimali831 wrote:
thanks again Smile
You are welcome Smile Thumbs Up
