Latest: lio94
Overall: 17181
Online Now [380]:
Visitors: 379
Today: 13488
Total: 141653204
Forums › The Car › 206 Talk › 180 Hub Nut talk
180 Hub Nut talk
19Connor92
PostPosted: Mon May 05, 2014 5:15 pm Up
after spending 20 mins being past around different departments at peugeot then being hung up on, still have no idea what the talk values are for the FRONT HUB NUT on 180?
anyone help?
Sim
PostPosted: Mon May 05, 2014 5:45 pm Up
They are not in Haynes manual for older Pugs either, so I'd say torque setting is FT (f***ing tight!) Very Happy
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
19Connor92
PostPosted: Mon May 05, 2014 6:24 pm Up
but i have had it before where you do it to fit and F..K the bearing?
PostPosted: Tue May 06, 2014 2:14 am Up
Why would Peugeot help you? They are in my Haynes manual.
PostPosted: Tue May 06, 2014 2:29 am Up
Is it any wonder the search function is a PITA to navigate. It's TORQUE not TALK
The answer is in the Haynes. Although it doesn't cover the 180 engine, bodywork and fittings are pretty much standard across the range.
The torque value will depend on if you have a staked nut or clip and capped set up, but more than likely most home mechanics torque wrenches won't go that high.
19Connor92
PostPosted: Sat May 10, 2014 5:01 pm Up
finally got through to peugeot there informed me that the 206 gti 180 hub nut torque is 245 Nm.
